Sump Pump Pit Never Opened To Ground Water - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 07:51 PM   #16
DIY staff
Rewards Points: 7,174
Even if you have perimiter drains--that crack will still seep water--it is above the drain.
Most cracks like that can be successfully fixed with epoxy injection---(around $300 for a single crack--less if you have others.
Curing the leak from the outside is the best--but major money and destruction of the landscaping--
Try the epoxy injection---
Old 06-23-2012, 11:58 AM   #17
Rewards Points: 1,418
Originally Posted by oh'mike View Post
What happen when you run water in that bathroom?
That looks like a sewage line (PVC) as opposed to the typical footing drain (Black corrugated pipe)
White PVC, with 3/8" to 1/2" holes about 6 inches apart the whole length, is perfectly usable for perimeter drains.
A sewage line should never come into and dump into an indoor chamber that is not hermetically sealed (except for inlet and outlet pipes).
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 09:05 AM
Draining water softener through sump pump nancygecs Plumbing 3 11-29-2011 07:31 AM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
sump pump "pit falls" bubbler Plumbing 6 03-09-2011 09:45 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
