I bought a house 2 years ago. It was built in 2003. The basement has a sump pump pit but the knock outs or area where the tile would come in were never opened, so no sump pump has ever been installed. Last year I never had any issues with water, but this year I have had a few instances where water has came in through the seems. It has been minimal but I would like to finish the basement and stop this issue before it worsens. I have a few questions.
1.) Is there going to be drain tile on the other side of the sump pit?
2.) Will installing a sump pump eliminate this problem?
3.) I'm assuming I need to get a pump installed and plumbed before opening the pit up.
I misunderstood, there is a sewer pit, but that is completely sealed. The basement is pumbed for a full bath. I was only talking about the sump pit for ground water.
The sump pit by itself, with some holes or slits in the sides and also a sump pump, will protect against basement flooding within an approximately four foot radius around it.
To get protection all the way around the basement you would normally need nearly horizontal drain tiles or perforated drain pipes aka a French drain all the way around the foundation under floor level, either just inside or just outside, those pipes emptying into the pit.
If the foundation and basement floor were built atop coarse gravel rather than sand or soil, the drainage into the pit may be fast enough to protect the entire basement without the need for perforated pipes.
I read somewhere that on newer houses they usually put perferated drain tile around the foundation and connect it to the sump pit. In a perfect world, I was hoping to cut into my sump pit and find these tiles on the other side. Is this likely?
A picture of the piping coming out of that pit will be needed---I bet that one contains your perimeter drain pipes----I know that it's sealed up---but opening it would give you the true answer--and not our guesses.
Well, I think your right. I never checked that because when I had the house inspected the inspector said that was for the removal of the waste for the bathroom that is in the basement. I'm assuming he didn't know what he was talking about, or did he? I guess if I have this working and only one point where water is seeping in, then I need to install a french drain or something.
The bathroom in the basement is nonexistant. There is some plumbing for it, if we ever decide to finish the basement in the bathroom, but there isn't a faucet or toliet.
There is a vertical crack down my foundation. It is leaking water into the basement. I have read a lot about this but not sure the right path to take. I was assuming that if I opened the sump pit and pumped out ground water than it may stop. Here is a photo of the crack. Should I leave the sump alone, and focus on patching this crack (from outside or inside?) and adding drain tile?
Even if you have perimiter drains--that crack will still seep water--it is above the drain.
Most cracks like that can be successfully fixed with epoxy injection---(around $300 for a single crack--less if you have others.
Curing the leak from the outside is the best--but major money and destruction of the landscaping--
Try the epoxy injection---
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
