Sump Pump Drains Into Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2014, 02:41 PM   #1
Rewards Points: 461
Sump pump drains into yard
Our sump pump drains into our home which we recently purchased. The area where it drains stays really wet. Is there any alternative ways to make it drain?
Is it possible to tie my gutter down spouts into the sump drain also?
cincinnati guy is offline   Reply With Quote
Old 04-14-2014, 02:50 PM   #2
Rewards Points: 6,652
You do not want your gutter down spouts going into the sump well. A good heavy rain will flood your basement in no time.
As for the discharge. Run the piping out if able to do so, to the city storm curb. If it discharges in the back yard, run it out as far as you can. Keeping in mind to slope it 1" for every 2', to allow all water to exit after running.
You did not put in where you live, or put up a picture from google maps or your own personal photos. Showing where the line discharges, or what is behind you.
In some areas you have to discharge the sump into a Dry Well. It is basically a chamber filled with rocks, to allow the water to seep back into the ground.
Old 04-14-2014, 03:11 PM   #3
Rewards Points: 461
I will get pictures soon of my current setup. We are in Cincinnati, Ohio area.
Old 04-14-2014, 06:45 PM   #4
DIY staff
Rewards Points: 7,174
If you can dig in an underground 4" drain---the sump discharge must drain into the larger ground pipe as a 'free fall'
Much like a faucet draining into a sink---this way if the underground pipe freezes or becomes clogged the sump pump will over flow harmlessly onto the ground.
Old 04-14-2014, 06:55 PM   #5
Rewards Points: 402
Mike makes a good point. If you put in a catch basin like this:
http://www.homedepot.com/p/Tuf-Tite-...ct_description
under your sump pump drain, and run a 4" line out to the street or other part of the yard, as long as it's lower than your house, you would be fine.
taylorjm is offline   Reply With Quote
The Following User Says Thank You to taylorjm For This Useful Post:
oh'mike (04-14-2014)
Old 04-20-2014, 12:46 AM   #6
Rewards Points: 461
Can I have the sump drain into the catch basin and it stays in it till its overflowing and flow out into whereever I choose for it to drain?
I see I need to add the antifreezing piece to it ive seen online.
Old 04-20-2014, 07:32 AM   #7
DIY staff
What you are describing sounds like a cistern---a large container to save the water --and a distribution system so the water can be used for watering the garden?
This can be done---a horse trough is a good example---a pump inside the trough could be used to power a sprinkler--or simply add hose connections to the trough and let gravity send the water where you want it.
Old 04-20-2014, 08:51 AM   #8
Rewards Points: 402
The only issue is that it wouldn't take long for your sump pump to fill up a small barrel or trough, then it's going to overflow right by your foundation, and go right back into your weeping tile and into the sump pump again, and probably start to leak through your foundation walls. You can't have it overflow right by your foundation like that, you need to get the water away from the house.
Old 04-25-2014, 09:36 PM   #9
Rewards Points: 461
What I am talking about is a drywell that will sit back in the far back yard underground surrounded with gravel. Ill have the PVC run underground to the drywell underground. In hopes that by time it fills up, all the water in it will disperse into the ground soil.
If it were to fill up I think I will have a valve that pops up and lets the water go out.
Old 04-26-2014, 11:10 AM   #10
Rewards Points: 402
So would this drywell be a solid holding tank so you could do something with the water at a later date?
Old 04-26-2014, 12:19 PM   #11
See my remarks. Basically a covered shallow well with a whole lot of rock in it, to allow for the water to drain into the ground.
Old 04-26-2014, 01:13 PM   #12
Rewards Points: 402
I guess I don't understand the reasoning behind digging up a bunch of ground, putting in a tank and gravel, only to let the water drain into the ground. Are you trying to avoid turning the yard into a pool?
Old 04-26-2014, 08:06 PM   #13
The purpose of a Sump dry well, is to keep from turning the yard into a pool, when the Sump is pumping out a lot of water.
Old 09-03-2014, 02:51 PM   #14
Rewards Points: 461
So I can get one of these and have the PVC piping coming from the sump pump dump the water right into this?
http://arlingtonlandscape.biz/roches...ter-dry-wells/
When digging the hole for the drywell, I need to put rocks inside and around it?
Id like to also get a few more of these drywells and do it with my gutter downspouts.
Old 09-03-2014, 02:55 PM   #15
Rewards Points: 461
Or I can have it drain in the same location but just get a drain outlet on it. Where can I find one of those and also the piece for freeze protection?
Exterior grade sump pump Jeeper1970 Plumbing 11 12-02-2016 10:17 AM
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 08:05 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
