-   -   stump removal technique (http://www.diychatroom.com/f16/stump-removal-technique-184690/)
bamaranch 08-03-2013 01:42 PM
Has anybody tried this? It seems too easy.
http://www.thisoldhouse.com/toh/phot...350083,00.html
I've got a tree with a trunk about 8 inch diameter in the interior corner of a fence (that would make even a stump grinder a pain to use).
joecaption 08-03-2013 02:25 PM
That will work, done it many times.
user1007 08-03-2013 08:28 PM
Some reason you cannot just saw it level with the ground and use a chemical stump or brush killer carefully? Is it hurting anything where it is. Why not leave it to nature ortherwise?
teeb57 08-19-2013 01:27 AM
I need to do the same thing. Did you get a chance to try it yet bamaranch?
mudpaws 08-22-2013 03:30 PM
What do they mean by vertical cuts AROUND THE STUMP, then dig a trench BETWEEN the cuts? I thought we were using a "SawsAll"...I'm having a hard time following that whole part....
teeb57 08-22-2013 03:42 PM
I didn't follow it too well at first either. I'm not sure if I can put a picture in your mind's eye but I THINK they want you to put a reciprocating saw vertically straight down into the ground and saw about 4" out from the tree stump and saw all the way around the tree. This will sever the thickest roots from the tree stump. Then go about another foot out away from the tree and repeat that process. Then dig the dirt between the two cuts you just made. By digging out this drench, you have a means to be able to get under the tree stump and try to pry the stump out of the ground.
I may not have it correct but I think this is what they're talking about.
mudpaws 08-22-2013 03:50 PM
Oh, ok. That makes more sense. I can try that with a couple trees here. One Pine, one Oak. Thank you!
teeb57 08-22-2013 03:54 PM
You betcha! The pine I would think would be ok with this method. Let me know how it works with your oak, I'll be interested to know.
Steve
noquacks 08-22-2013 04:59 PM
ifn one has to, one has to grind/chemicalize/chop a stump out no matter what the cost . I leave mine for nature, as another member suggested. 2 years. Patience.
teeb57 08-22-2013 11:15 PM
I've put chemicals in a stump before. When I moved out 3 years later, the stump was still there. But it could've been the type of tree or wrong chemicals. I've placed chemicals in the stump I'm dealing with now, it's been 6 months with virtually no change. Good luck with yours. While I'm no expert on this subject, I find it difficult to believe I can make a stump go away in two years.
trawilson01 08-23-2013 01:16 PM
i have an old stump that i have cut on and hammered on and even burned some... it still remains after about 6 or 7 years. i think i am about to dig under it and cut every root i find.
maybe i'll dig through to china:laughing:
Polly003 08-24-2013 10:20 AM
I had an old Arizona Ash in San Antonio, but off about 3" above ground, maybe 12 diameter. Did all sorts of stuff, including Stump-Out, hacking at it, drilling holes, etc. Finally mounded dirt over the whole thing, popped a larger plastic planter on top (upside down), watered through the drain holes in the planter and kept it soggy for a few months. I had another smaller pot on top with flowers, so from the street it just looked like a stand for my pot.
When I moved the pots and dug out some dirt a few months later, the stump was rotting away. Just covered it up and left it about a year. By that time, the dirt, water, and bugs had rotted the stump to below the ground level, and I was able to just shovel it off. Don't know how well it would work on other tree stumps or other locals, but it was the only thing that worked for me.
teeb57 08-24-2013 01:47 PM
Did you try the suggestion on the 1st post in this thread? I was curious if cutting around the stump with a recip. Saw would really Work
Polly003 08-24-2013 02:07 PM
No, we did not do the trench around the tree, cutting roots, method. This was in oily black, gumbo type dirt, slick/sticky when wet; hard as a rock when dry. Will kill any saw blade in a minute if you could even get it to make the first cut.
