Stump Grinding - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-21-2007, 05:05 PM   #1
Rewards Points: 150
stump grinding
Is stump grinding something I can do myself? Can you rent the grinder, or use maybe a chain saw and just cut the thing to smitherines?
elementx440 is offline   Reply With Quote
Old 03-22-2007, 10:19 PM   #2
You can probably rent a grinder but they're big, heavy and cumbersome and it takes a while to grind the stump. I wouldn't recommend a chain saw... too close to the ground to be safe.
pipspeak is offline   Reply With Quote
Old 03-23-2007, 11:58 AM   #3
Rewards Points: 1,088
Definitely do not use a chain saw. If anyone has used a chain saw before, you know that you're not supposed to let the chain touch dirt, which can quickly dull the chain. If you're even considering renting a stump grinder, for that cost, you could rent a Bobcat and dig it out. Depending on where you live, you can just burn the stump afterwards. Also, depending on the size of the stump, if it's not too large, you can buy a chemical that will eat the stump up.
handy man88 is offline   Reply With Quote
grinding concrete amakarevic Building & Construction 1 08-14-2007 08:09 PM
can i just saw the tree's roots to get that stump out? joeyboy Landscaping & Lawn Care 14 05-31-2007 12:18 PM
Tree stump mdlbldrmatt135 Landscaping & Lawn Care 2 06-16-2006 01:31 PM
faucet seat grinding belcas Plumbing 2 02-06-2006 01:50 PM
