-   -   stump grinding (http://www.diychatroom.com/f16/stump-grinding-7279/)
elementx440 03-21-2007 05:05 PM
stump grinding
Is stump grinding something I can do myself? Can you rent the grinder, or use maybe a chain saw and just cut the thing to smitherines?
pipspeak 03-22-2007 10:19 PM
You can probably rent a grinder but they're big, heavy and cumbersome and it takes a while to grind the stump. I wouldn't recommend a chain saw... too close to the ground to be safe.
handy man88 03-23-2007 11:58 AM
Definitely do not use a chain saw. If anyone has used a chain saw before, you know that you're not supposed to let the chain touch dirt, which can quickly dull the chain. If you're even considering renting a stump grinder, for that cost, you could rent a Bobcat and dig it out. Depending on where you live, you can just burn the stump afterwards. Also, depending on the size of the stump, if it's not too large, you can buy a chemical that will eat the stump up.
