Stump Gone - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 08:32 PM   #1
Rewards Points: 1,088
stump gone
Neighbor had a huge wild cherry taken down today, and the tree folks offered to grind my stumps for $175. I went ahead and had it done, so the area is now dirt mixed with pulverized stump/saw dust....not large wood chips.
What do I need to do to amend that stuff to make it better for planting veggies come spring time. I figure some peat moss and top soil.
Do I need to put down a spray of termite killer? The 3 stumps came from a silver maple, a sugar maple, and a bradford pear.
handy man88 is offline   Reply With Quote
Old 01-28-2012, 09:10 PM   #2
Too Short? Cut it Again!
You seem on the right track mixing the sawdust and shavings into a planting mix. Just remember the wood will decompose and break down. It will draw nitrogen from the soil as it does this so you may need to supplement your regular vege feedings with a little added nitrogen fertilizer---such ammonium sulfate. Ask your local nursery.
You should get a Ph kit so you can watch that and adjust accordingly.
I don't think termites will be an issue but if they are this is one instance where you should let them do their thing. They will not hurt your veges and will speed decomposition of the stump material. Obviously if the stumps are right up near the house you will want to do something.
Do be prepared for some settling.
The Following User Says Thank You to user1007 For This Useful Post:
handy man88 (01-28-2012)
Old 01-29-2012, 05:26 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
[quote=sdsester;837432]You seem on the right track mixing the sawdust and shavings into a planting mix. Just remember the wood will decompose and break down. It will draw nitrogen from the soil as it does this so you may need to supplement your regular vege feedings with a little added nitrogen fertilizer---such ammonium sulfate. Ask your local nursery.
Do be prepared for some settling.[/quote]
Yes and it could be a LOT and take YEARS.
Old 01-29-2012, 08:43 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... The Best thing to do is get Rid of the grindings,...
Use 'em for mulch or whatever...
Then fill the depressions with top dirt...
Nothin' will grow in the grindings, as stated above, they'll draw Nitrogen outa the soil...
Which of course, is why they make Good mulch...
Old 01-29-2012, 10:09 AM   #5
[quote=chrisn;837702]
Thanks, but of the 3 stumps that were ground, the biggest was only about 18 inches in diameter. Went about 12" below grade.
I will be growing veggies in that area, not grass.
Preserving A Tree Stump Pointgirl Landscaping & Lawn Care 1 07-14-2011 10:07 AM
Rent a stump grinder or "hire" a stumpgrinder? CoconutPete Landscaping & Lawn Care 32 04-18-2011 09:20 AM
How to keep a tree stump from rotting. richcharity Landscaping & Lawn Care 2 06-08-2010 06:20 PM
How to prevent tree stump from rotting? Jeremy Hillary Boob, PhD Landscaping & Lawn Care 8 06-21-2009 09:16 AM
can i just saw the tree's roots to get that stump out? joeyboy Landscaping & Lawn Care 14 05-31-2007 01:18 PM
