-   -   stump gone (http://www.diychatroom.com/f16/stump-gone-131742/)
handy man88 01-28-2012 08:32 PM
stump gone
Neighbor had a huge wild cherry taken down today, and the tree folks offered to grind my stumps for $175. I went ahead and had it done, so the area is now dirt mixed with pulverized stump/saw dust....not large wood chips.
What do I need to do to amend that stuff to make it better for planting veggies come spring time. I figure some peat moss and top soil.
Do I need to put down a spray of termite killer? The 3 stumps came from a silver maple, a sugar maple, and a bradford pear.
sdsester 01-28-2012 09:10 PM
You seem on the right track mixing the sawdust and shavings into a planting mix. Just remember the wood will decompose and break down. It will draw nitrogen from the soil as it does this so you may need to supplement your regular vege feedings with a little added nitrogen fertilizer---such ammonium sulfate. Ask your local nursery.
You should get a Ph kit so you can watch that and adjust accordingly.
I don't think termites will be an issue but if they are this is one instance where you should let them do their thing. They will not hurt your veges and will speed decomposition of the stump material. Obviously if the stumps are right up near the house you will want to do something.
Do be prepared for some settling.
chrisn 01-29-2012 05:26 AM
[quote=sdsester;837432]You seem on the right track mixing the sawdust and shavings into a planting mix. Just remember the wood will decompose and break down. It will draw nitrogen from the soil as it does this so you may need to supplement your regular vege feedings with a little added nitrogen fertilizer---such ammonium sulfate. Ask your local nursery.
Do be prepared for some settling.[/quote]
Yes and it could be a LOT and take YEARS.
Bondo 01-29-2012 08:43 AM
Ayuh,... The Best thing to do is get Rid of the grindings,...
Use 'em for mulch or whatever...
Then fill the depressions with top dirt...
Nothin' will grow in the grindings, as stated above, they'll draw Nitrogen outa the soil...
Which of course, is why they make Good mulch...
handy man88 01-29-2012 10:09 AM
[quote=chrisn;837702]
Thanks, but of the 3 stumps that were ground, the biggest was only about 18 inches in diameter. Went about 12" below grade.
I will be growing veggies in that area, not grass.
