Storage Shed Critter Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 08:11 PM   #1
Rewards Points: 107
Storage shed critter problem
We have as large 8 x 10 plastic storage shed in our yard. It sits on a platform and underneath is gravel as well as 3 PVC pipes for drainage. We had a mouse infestation and cleaned out the entire shed. What a mess! They got into seed, soill, chewed up plastice furniture covers, etc. Two scurried out during our clean up, but we noticed several running around underneath the platform and in the drainage pipes which are somewhat clogged and they are probably nesting there.
Any ideas for effective critter removal and prevention?
Thanks.
Ranger1227 is offline   Reply With Quote
Old 04-08-2013, 07:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... Mouse traps, Decon, or a Cat, yer choice...
Bondo is online now   Reply With Quote
Old 04-08-2013, 07:07 AM   #3
Rewards Points: 13,446
Also clean out the drains, add some hardware cloth as a screen over the outlet.
Old 04-08-2013, 08:17 AM   #4
Rewards Points: 107
Thanks for the suggestions. We are somewhat leery of poison as it could affect other animals. I read about spreading coyote urine pellets, which we already have, so may try that after cleaning out everything. Can the chew through hardware cloth? I suggested that to DW last night but she thought they could chew through it
Old 04-08-2013, 10:11 AM   #5
Rewards Points: 12
As long as the food supply and protection from the elements are there, the mice will try to be there too. Unless you can effectively seal all entrance points, which is likely not realistic, the only long term solution is to use poisoned traps, but glue boards, and even that is an uphill battle as new mice will continue to come in.
needhelpbad is offline   Reply With Quote
Old 04-08-2013, 10:29 AM   #6
Rewards Points: 3,514
They won't chew through the hardware cloth.
Canarywood1 is online now   Reply With Quote
Storage Shed - Buy or Build dougp23 General DIY Discussions 21 11-22-2011 07:34 AM
Sinking Shed willise Building & Construction 3 05-04-2011 11:34 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Base for Storage Shed cbsrugby Building & Construction 6 05-08-2008 01:41 PM
