Which Stones To Use For Landscaping - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 08:22 PM   #1
Which Stones to use for landscaping
I am planning to surround my home borders with decorative stones.
Not sure which stone to be used so that they look good and does not create a problem in long run.
Also I would be needing a lot of stones.
Could you please advise any one who can supply in bulk.
I know homedepot and lowes have them packed in a 0.5 Cubic feet bag.
But i will be needing a lot more than that.
Please advise if some one has already done this for their home,
btw I am in Central NJ
thanks
saithani
saithani is offline   Reply With Quote
Old 07-31-2011, 10:31 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
thanks
saithani
I strongly prefer mulch, it is much better for the plants and trees. However rocks will last longer without maintenance if that is your goal.
Your likely going to need to have a quarry come out with a truck load if your doing any kind of size able area.
Remember, spreading rocks is a "ton" of really hard work.
If your not dead set on rocks, check out all the different looks of mulch you can get now. Otherwise, make some calls to nearby quarries, or if none, larger landscaping places.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
The Following User Says Thank You to jamiedolan For This Useful Post:
saithani (07-31-2011)
Tags
bulk , decorative stone , landscaping
Using faux stones to create a tree ring Mike Rynearson Landscaping & Lawn Care 1 06-04-2011 05:22 PM
Flagstone Path - How to Fix Unstable Stones jbk Landscaping & Lawn Care 2 10-29-2010 04:59 PM
Mixing floor types: laminated + stones: possible? bruyeria Flooring 1 05-07-2009 07:16 PM
Grouting Natural Stones Solrac22 Remodeling 7 04-04-2009 06:23 AM
Easiest stones use to lay outside? KUIPORNG Landscaping & Lawn Care 6 06-27-2006 08:37 PM
