Stone Wall Re-alignment - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 12:50 PM   #1
Stone wall re-alignment
Hello,
I know is is probably the dumbest question you have received here but I figured "the pros" on here would know how to handle this in the correct manner. I have a few stone walls as you can see in the pictures that need to be fixed. Over the years due to extreme freezing/thawing cycles this is what I have. I need to bring the stones closer together and be level again. Any suggestions on the proper landscaping technique(s) and sequence would be greatly appreciated. Also is there any way to prevent this from happening in the future? Thank you for all your time!
Unclev is offline   Reply With Quote
Old 04-03-2012, 06:37 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... They appears to be just stacked stones....
Knock 'em down, 'n Restack 'em....
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 06:39 PM
Field Stone and Mortar Wall, will it be stable? NorskeDiv Landscaping & Lawn Care 4 07-14-2011 10:18 AM
dry stack natural stone retaining wall diy001 Landscaping & Lawn Care 17 06-20-2011 11:57 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
