Stihl Hs46 Hedge Trimmers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-25-2012, 09:54 PM   #1
stihl hs46 hedge trimmers
brand new, just bought 2day from dealer. when i can get it runnin after trying to turn it over dozens of times, idles poorly. bogs down when adding throttle.
does anyone have an explanation for this? am i going crazy?
funkjosh is offline   Reply With Quote
Old 05-26-2012, 07:54 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,058
Ayuh,... Are ya usin' the Choke,..?? are ya turnin' it off, when it starts,..??
If all else fails, bring it back to where ya got it, 'n ask Them what's up with it...
Bondo is online now   Reply With Quote
Old 05-26-2012, 09:13 AM   #3
Rewards Points: 13,456
Look on the side of the carberator, there should be two screws. One's marked H and one's marked L.
It high and low speed adjustments.
Try backing the L screw out (counter clock wise) an 1/8 of a turn at a time and see if that helps.
Old 05-26-2012, 09:24 AM   #4
Rewards Points: 236
mine has to warm up a little, before it runs well. and if it is cold outside, it does not run well until it is really warmed up.
same for my leaf blower.
and i hope you didn't put E85 gas in it.
Fix'n it is offline   Reply With Quote
Old 05-26-2012, 02:21 PM   #5
gas vapors
finally got it goin pretty good. adjusted L screw and primed the **** outta of it (the guy at dealer told me not to prime it more than 4 times, shows what he knows).
the gas i was using was midgrade and not to old (few weeks).
can anyone enlighten me on what the effect of open containers has on gas? is the gas less potent because of the release of vapors?
hedge trimmers and lawn edgers ? Fix'n it Landscaping & Lawn Care 8 05-14-2012 09:35 PM
string trimmers: what do the pro's use? av-geek Landscaping & Lawn Care 6 04-30-2012 10:09 PM
Forsythia for privacy hedge? Badfish740 Landscaping & Lawn Care 2 08-25-2011 02:39 PM
Stihl vent tripleup05 Landscaping & Lawn Care 3 05-05-2011 11:10 PM
Hedge trimmer, cut through the wire (how can I fix it) BostonsBadBoy Electrical 13 10-16-2009 06:29 AM
