Standing Water In Garden - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 09:03 AM   #1
standing water in garden
I was wondering how to remove standing water from my garden area. everytime it rains it fills up with water.
tammysullivan is offline   Reply With Quote
Old 03-29-2012, 10:44 AM   #2
Rewards Points: 12,858
In most cases it's best to just raise the grade by adding some fill, instead of trying to figure out how to add drainage.
Old 03-29-2012, 04:32 PM   #3
Too Short? Cut it Again!
Jeeze Louise Joe. This has to be your worst comment yet!
The last thing you want to do is start shoveling dirt or other fill at a grading or drainage problem you have not figured out or resolved. You will most likely not resolve the issue and more than likely you will, even if slightly successful, move the water somewhere else where you are even more unlikely to be able to deal with. And you will have a giant mountain or hill where water used to pool.
The op should get a landscape contractor, grading contractor, or even a civil engineer out to figure out what is going on with the lay of the land and why water is pooling. Especially so if this is a problem not unique to his property.
Old 03-29-2012, 09:21 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 342
Ayuh,.... Water flows Downhill....
Lower the grade in the direction you want the water to flow,...
You have a dam somewhere now, that's why ya get the lake...
Ayuh,.... Donno what yer Smokin', but I want some....
A Contractor,..?? An Engineer,..??
It's a Garden for christ's sake......
Bondo is online now   Reply With Quote
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
