Standing Water In Ditch - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 01:26 PM   #1
Question
Standing Water in Ditch
Hello,
I've got a ditch in my backyard that's approximately 75' from end to end, with an inlet on one end and an outlet on the other end. The water is supposed to drain through the ditch, and out the outlet into the city sewer system. Unfortunately, the water doesn't flow past the first few feet, and I wind up with a pool of standing water. The water is between 4 and 6 inches deep.
I'm trying to figure out how to get the water to drain properly. My first thought was to add dirt to where the water is pooling to try and make that higher than the outlet, but maybe I need to regrade the entire ditch?
Any advice would be appreciated.
ibuys is offline   Reply With Quote
Old 11-20-2009, 05:25 AM   #2
Add dirt first; if that's ineffective, go with Plan 'B'!
Lali is offline   Reply With Quote
Old 11-20-2009, 05:34 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... Continuous pitch is what you need,.... The amount of available fall determines how tough that is to accomplish...
Raising the inlet, or lowering to outlet will help, if that's possible..
Old 01-15-2010, 11:55 AM   #4
got a laser level? eye level? if not rent one or borrow one. take some elevations to see if you have enough slope to make the water run. If there is enough slope, remove dirt from high end and place in low end. 1 inch from high end and placed in low end will give you 2 inches difference
Larry
LarryS is offline   Reply With Quote
Tags
ditch , standing water
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Any ideas for standing water in my backyard? creamaster Landscaping & Lawn Care 16 01-13-2009 11:58 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
