Standing Water On Concrete Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 07:57 PM   #1
Standing water on concrete patio
My original patio has been extended. After the first rain, I noticed a large puddle of water on the patio. How can I correct this problem?
hilltop25 is offline   Reply With Quote
Old 03-11-2010, 08:15 PM   #2
Is it solid concrete ? Not concrete blocks ?
If its the add-on it sounds like they didn't slope it correctly
Old 03-12-2010, 09:33 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... It's gonna take Alot more explanation, or pictures to get any real Answers...
Water flows Downhill... your's Can't for some reason...
Probably a poorly poured slab like Dave says...
Old 03-17-2010, 06:15 PM   #4
Is there any way to correct the grade without having to redo the whole patio. Most of the work was done by me with the help of a couple of friends. I really do not have the money to start completely over. Is there a way fill in the area that is sunken?
Old 03-17-2010, 08:26 PM   #5
A picture would help
But basically if the grade is wrong then part of it needs to be pulled up & regraded
Old 03-18-2010, 12:31 PM   #6
Bondo's Avatar
Rewards Points: 594
Nope,.. Not really, especially if you want it to last...
Quick,+ simple way would be to grind a groove to drain it...
Standing Water in Ditch ibuys Landscaping & Lawn Care 3 01-15-2010 12:55 PM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-20-2009 12:53 AM
repairing concrete patio flooring & attached walls 1655graff Remodeling 2 01-21-2009 01:21 PM
Slightly Different Standing Water Question jlaky2000 Landscaping & Lawn Care 1 05-05-2008 08:20 PM
