Standing Water - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 11:12 AM   #1
Standing water
I recently did landscaping in my back yard, and since the completion, I have standing water towards the outer part of my yard by my gate. The original project was putting #2 river rock along my fenceline. Excavater was used and in the process, my backyard (grass) was ruined. So I added dirt, graded, seeded. Where did I go wrong? The water is actually above the rocks.
ANY IDEAS???????
mablack1970 is offline   Reply With Quote
Old 06-09-2009, 08:11 PM   #2
No idea without more info/pics but it sounds like you have created a dam that is keeping water dammed up that used to drain naturally.
Mike in Arkansas is offline   Reply With Quote
Old 06-12-2009, 03:18 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,... The Problem is with Your grading,....
Water flows Downhill,... You built a Dam....
Old 06-13-2009, 08:56 AM   #4
LandDesigns
You have a few options to rectify the situation.
As mentioned, it appears that the grade at your property line is actually now higher than the land sloping towards it, so the water now has nowhere to go.
1. Re-grade so that there is a gentle slope towards your property line. Of course this depends on your property and if this is possible. I tend to think there was an original issue due to the fact that river rock was to go at the edges.
2. If for some reason this is not possible, you could create a rain garden. This would be a bed that would be planted with plants that like wet conditions. In addition, you could add a more permeable soil to the area by mixing in sand.This will help the drainage.
3. Install a lawn drain in this area. Grade towards it and install a drainage pit to collect the water. This is similar to a drum with holes at the sides, allowing water to percolate out.
Susan
http://www.landscape-design-advice.c...e-grading.html
Last edited by Susan Schlenger; 06-13-2009 at 08:58 AM. Reason: link does not work
Susan Schlenger is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Any ideas for standing water in my backyard? creamaster Landscaping & Lawn Care 16 01-13-2009 11:58 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
