Stacked Block Wall? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 05:03 PM   #1
Rewards Points: 358
stacked block wall?
when planning this stacked block wall (similar to allan blocks) I notice the directions call out for landscaping fabric behind the rock drainage column. I question this because I have seen landscaping fabric break down in a number of years.. So I wonder is it really worth it, if it will break down soon anyway?
Thanks!
cbzdel is offline   Reply With Quote
Old 07-30-2010, 05:25 PM   #2
cbzdel, Fabric behind the drainage column is not always necessary. The purpose of it, is to minimize the amount of soil that may filter into the drainage column. Depending on how high your wall is you may or may not want to install it. Most commercial applications do not require it. Hope this helps. For some good reads on Soils, go here. http://www.goarticles.com/cgi-bin/showa.cgi?C=3087659
Kurtzilla is offline   Reply With Quote
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 12:11 PM
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 02:32 PM
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 12:25 PM
Patch cement block wall? k.kuenn Building & Construction 4 05-31-2009 08:40 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
