| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
The Three Lines in Indoor Soccer
by Expert Village
In this clip we are going to talk about the three lines. Now what that is is there is a middle line, where mid-field is. Then there are also two lines about eighteen yards out from the goal. And to kind of keep the ball in a controlled area so people... Read More »
How to Install the Valve for a Sprinkler System
by Expert Village
Hi I'm Fernando with Expert Village where going over installing a valve. The valve as I mention before the controlling hub here is the actual timer and this is a power unit. The power is distributed to the valve base on this controller and the timer... Read More »
Hooking Up a Starter Solenoid's Electronics
by Expert Village
In this clip, we're going to talk about the proper service procedure in order to diagnose, remove and replace your vehicles starter solenoid. In this step, we're going to talk about the proper way to hook up your starter solenoid back to the rest of the... Read More »
Diagnose a Car Starter's Command Wire
by Expert Village
In this clip, we are going to talk about the proper service procedure in order to diagnose remove and replace your vehicles starter solenoid. In this step we are going to talk about what starter solenoid is and the proper way to diagnose the command wire... Read More »
Watering Pesticides & Leeching
by Expert Village
Lets talk about the dry herbicides and insecticides that you may apply to your yard and the effect of moisture on them. We talked about the effect of a rain coming on top of a liquid application that you might use as a fluctuant to stop the product from... Read More »
