Sprinkler System Winterize? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 04:30 PM   #1
Rewards Points: 30
Hello,
I moved into a new house and I was wondering if I need to blow out my sprinkler system. Heard there are some that need it and some that don't. How do I tell?
Thanx!
psychoguy42 is offline   Reply With Quote
Old 10-14-2013, 04:43 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Where are you located, geographically?
brockmiera is offline   Reply With Quote
Old 10-14-2013, 04:49 PM   #3
Rewards Points: 30
I live in the very northern part of Indiana.
Old 10-14-2013, 04:54 PM   #4
brockmiera's Avatar
I've never heard of a sprinkler system that you dont have to blow out in order to avoid the damage caused by freezing water left in the pipes. I thought maybe if you were in an area that didn't freeze you'd be fine but if I were you I'd blow them out.
I was in your same shoes a couple years ago. I didn't blow my out because I simply didn't know better and when I turned them on the next year I had a crack the length of my ball valve.
The Following User Says Thank You to brockmiera For This Useful Post:
psychoguy42 (10-14-2013)
Old 10-14-2013, 05:02 PM   #5
Rewards Points: 582
if your temps get below freezing you have to winterize you system ..blow out water as most do... some blow out water and pump in antifreeze ... ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
anyone know how to winterize a sprinker system? denemante Landscaping & Lawn Care 3 11-15-2012 08:55 PM
DIY sprinkler system kimbhoot Plumbing 2 06-15-2012 11:01 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
what compressor can I use to blow out sprinkler system? Leoskee Landscaping & Lawn Care 12 02-04-2010 05:07 PM
Sprinkler System Nathan Landscaping & Lawn Care 1 02-09-2004 11:12 PM
