Sprinkler System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-14-2011, 11:41 AM   #1
Sprinkler system
we recently moved into this house and originally thought we did not have a sprinkler system because we dont see any controls. We recently spotted some Toro sprinkler heads. Closest to the house there is what looks like a sprinkler head with a little cap on top that says manual bleed. When this is unscrewed it look like what a dip stick would look like. We have looked everywhere and cannot find any place to turn on the system. Any ideas?
Coleen is offline   Reply With Quote
Old 08-14-2011, 03:43 PM   #2
seansy59's Avatar
Rewards Points: 258
That was your control valve, and you probably have more. Look for underground boxes, control wires, timers, valves. Start looking. Although the system may be abandoned.
You can look in you basement or crawlspace for a water valve going to the system.
Although, with the way you just described it "Closest to the house there is what looks like a sprinkler head with a little cap on top that says manual bleed", the system is in rough shape, those valves should be underground.
You may just want to call an irrigation expert in to get the system into order if it still exists. They'll take care of it all, although with a nice bill if you want them to get it operational.
You can also make a call to the past owners to ask them.
seansy59 is offline   Reply With Quote
Old 08-14-2011, 06:47 PM   #3
Rewards Points: 5,336
Controls can be in the garage, the room where the electric panel is, or in a closet. Look around the outside of the house. At some point the wires need to enter a building.
My wires enter the house through the same hole as the water pipe to the valve box.
Ron
B. Franklin 1759
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Lawn sprinkler system - changing heads - ? SixStrRzr Landscaping & Lawn Care 1 08-16-2010 08:01 PM
what compressor can I use to blow out sprinkler system? Leoskee Landscaping & Lawn Care 12 02-04-2010 04:07 PM
Sprinkler System Jeep Landscaping & Lawn Care 6 06-06-2008 05:27 PM
Sprinkler System Nathan Landscaping & Lawn Care 1 02-09-2004 10:12 PM
