Sprinkler: Splice PVC Onto Older NONthreaded Galvanized? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 04:18 PM   #1
Sprinkler: Splice PVC onto older NONthreaded Galvanized?
I have an issue where a long stretch of older galvanized sprinkler pipe is run under a fair amount of concrete (30 foot straight run or so). It's so much, that cutting the concrete, and placing new PVC is out of the question.
That said, I need to do some sprinkler modifications and adjust where the head is (as it will soon be covered in concrete).
Ideally, I could find a good way to tie in the galvanized to a PVC, and unfortunately, where it would have to be tied in there will be no thread on the galvanized pipe. I am told this is hard to do.
My questions are thus.
1) Considering the usage (sprinkler watering for 10min 3 times a weak), is there a decent way to tie in a un-threaded galvanized pipe to a PVC one?
2) Would it be easier/longer lasting if I tied galvanized into a copper pipe instead? (this portion of the sprinkler system is the very last, little bit)
3) Is there some easy way to push out a 30 foot section of pipe and replace with PVC that I am not aware of? Or some alternative to replace the galvanized pipe without breaking up all the concrete it is underneath?
Thanks!
kronic24601 is offline   Reply With Quote
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 12:40 PM
