Sprinkler (low water flow)
The previous owner of the house told me that he de-activated one of the sprinker zones, to make the grass in that zone wither so he can do something else with that place. Since I see that the zone is also suppose to cover other plants/trees, I went to the controller to turn it back on. It actually was programmed for that zone to be on, so at first could not figure it out Then I saw that for the solenoid (?) , one of the wires was actually cut. So re-connected the wire and the water now comes out but barely. Just trickling out the pipes (PVC). There isn’t any control I can see other than the handle at the top (photo attached), I played around with it, doesn’t change the flow. Is there anything else I can try? Is this related to the fact that those set of pipes hasn’t had any flow for many many years? Any remedy for this? Thank you.
