Sprinkler Head Doesn't Rotate - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 11:05 AM   #1
Sprinkler Head doesn't rotate
Hey there I have a (hopefully) simple question . . . I have a sprinkler head in my lawn that doesn't rotate. It just pops up and sprays water in one direction.
I have a few questions . . .
can anyone tell what brand my sprinkler heads are by looking? I've attached a couple of pictures.
Are sprinkler heads universal (in case I have to replace it, do I need a specific brand)?
Do you think there's any way to fix it without replacing it?
If I do have to replace it, do I just dig a hole, unscrew the bad one, put the new one on? Simple as that?
Thanks!
FlatBot is offline   Reply With Quote
Old 05-15-2012, 11:31 AM   #2
kmc
Get the same model head. Then cut the outer edge of a donut hole neatly with a straight shovel about 12" diameter to about 2" deep to remove the ring of sod in one or two pieces. Set the sod asside and continue digging the hole down to below the riser that is under the sprinkler. With a pair of pliers hold onto the riser with one hand and with your other hand unscrew the head. Replace with the same head making sure to keep the fixed side of the rotation in place (right or left side depending on model). You will want the owner's manual to learn how to do that.
As far as identifying the head, is there a cap missing? Can you take a pic of the side of it including the nozzle where the water comes out of?
kmc is offline   Reply With Quote
Old 05-15-2012, 11:57 AM   #3
upon closer inspection I can see that it is a "Toro Super 700" sprinkler head. This is one that rotates 360 degrees.
This page sells what I think is the same thing
http://gplawn.com/p-1078-toro-super-700-rotor-head.aspx
"Toro S700-FC, 360 Degree Arc, 3 Inch Pop-up, w/o Nozzle"
But there's no nozzle. . .
Do you think I can remove the Nozzle from my old one and stick it in the new one? Or should I find one that comes with a nozzle? Not sure how hard it is to swap the nozzle.
Old 05-15-2012, 03:04 PM   #4
Rewards Points: 3,342
You dont need the same brand,they are pretty much all alike in that they turn 360 degrees and all are adjustable, Rain Bird, Hunter, and Toro are the better brands and you can get them at Home Depot or Lowes,about $10.00/$12.00 dollars.
Forgot to say some heads come with different nozzles to match current flow rate,Orbit is one.
Canarywood1 is online now   Reply With Quote
Old 05-15-2012, 06:43 PM   #5
kmc
If it were me, I'd definitely replace with the same one. The different heads vary in flow rate and precipitation rate. Don't mickey mouse a system that was set up correctly. Now with that said, ID a few other heads to verify that they are the same as the OP. If you have a hodge podge, then do as the last post said because it won't really matter at this point.
It looks like you found the right head. If you don't want to wait, that head can be had locally at an irrigation store. You'll have to look it up in your area. Just google maps "irrigation store" and your zip. The stuff at HD is often home owner stuff. The black is commercial grade (usually).
Sprinkler, is the strongest head.. likely the first or the end of the line caseynshan Landscaping & Lawn Care 1 05-19-2011 07:16 AM
Sprinkler head helpings!!???!!?? seansy59 Landscaping & Lawn Care 3 05-13-2011 07:58 AM
sprinkler head looking thing brianford Electrical 11 03-28-2011 08:13 PM
Ceiling fan & Sprinkler Head Mike2401 Electrical 0 08-28-2010 12:49 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 07:39 PM
