Sprinkler Head - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 11:53 AM   #1
Rewards Points: 2,152
sprinkler head
Tried to edit my post on this topic from 8/31, but there is no longer an edit button.
Here's a photo of the sprinkler head which sticks up and I have to mow around. I couldn't twist it off until today when I dug around it then I grabbed the big part and twisted it off.
Now I wonder why there's still water in the white underground line? The irrigation hasn't been used for a couple of years. I don't ever plan to use it again. So what do I do with it.....just throw dirt over it? Or should I figure out how to block the white end which has the water? Thanks.
Startingover is offline   Reply With Quote
Old 09-30-2013, 11:58 AM   #2
Rewards Points: 22
You should cap it off. It should be a 1/2 pipe but pick up a 3/4 inch just in case and return the one you don't use.
If you just throw soil over it, you'll ruin the line for anyone in the future that decides to use that part of the irrigation system.
http://www.homedepot.com/p/Unbranded...5#.UkmtexDVEU5
http://www.homedepot.com/p/Mueller-S...4#.UkmtWRDVEU4
Dan
djlandkpl is online now   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Startingover (09-30-2013)
Old 09-30-2013, 12:05 PM   #3
THANKS!!! That's cheap enough to cap it off. I didn't even know they made those little caps.
Yes, I would have felt badly about throwing dirt over it. Of course I don't know how anyone would even know where it is when I cap it, but I'll try to remember.
If I win some lottery money I would use the irrigation again!
Old 09-30-2013, 01:33 PM   #4
Rewards Points: 6,652
I would mark on the sprinkler layout, which head that was removed, and what zone it is on. That way any future buyer of the property, would know that head is out of the loop. It may also change the pressure in that zone, which means other heads will have more water coming out of them.
As for the cap, you can also get the glue on caps and just cut the pipe past the elbow, and cap the stub there also.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 09-30-2013, 02:42 PM   #5
what sprinkler layout? No one gave me one last yr when I bought this house, but I will draw one up myself. And I just remembered another one of those things broke off, in the front yard.
I think this system is original, so 30 yrs old. Maybe someone else would want to start from scratch with a new system someday.
I wouldn't be able to cut the pipe.
Still wonder how there could be water there after all this time?
thanks
Old 09-30-2013, 03:15 PM   #6
Rewards Points: 22
The pipes are the low point in the system so water will always remain. Some systems have drains installed to let the water out but my gut is that most do not. Up North we have our systems blown out with compressed air before the winter to prevent the pipes and heads from freezing.
Dan
sprinkler head Startingover Landscaping & Lawn Care 7 08-30-2013 08:14 PM
flexible head, or relocating rain bird sprinkler head? denemante Landscaping & Lawn Care 4 05-13-2013 08:23 AM
Sprinkler Head doesn't rotate FlatBot Landscaping & Lawn Care 4 05-15-2012 05:43 PM
sprinkler head looking thing brianford Electrical 11 03-28-2011 07:13 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
