Sprinkler Head - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 12:29 PM   #1
Rewards Points: 2,218
sprinkler head
There's an old, big sprinkler head that sticks up and I have to mow around. I won't ever be using irrigation in that part of the lawn.
How do I remove the sprinkler head? Do they twist off? I tried that but maybe needed more force.
thanks
Startingover is offline   Reply With Quote
Old 08-30-2013, 02:22 PM   #2
Rewards Points: 1,016
usually they are threaded on - threads may be locked up. suggest to dig out around it so you can get to the feed line and get a better view and grip. if the feed line is still being used you will need to plug where it is removed.
____________
Vince
The Following User Says Thank You to vsheetz For This Useful Post:
Startingover (08-30-2013)
Old 08-30-2013, 02:38 PM   #3
Rewards Points: 91
Also don't forget to shut off the valve that goes to that particular zone/head.
NegativeTen is offline   Reply With Quote
The Following User Says Thank You to NegativeTen For This Useful Post:
Old 08-30-2013, 04:42 PM   #4
I haven't used the irrigation since I moved in last yr and probably won't, cause the well doesn't work and I'm not paying for city water.
Ok, I'll dig around it and see what's what. What would I plug it with?
It's just annoying to have to mow around it every week.
thank you
Old 08-30-2013, 06:30 PM   #5
Rewards Points: 44
thank you
Post a pic once you dig up the head. The "plug" will vary depending upon how the head was installed.
Some heads are installed with a flexible line. If it works out in your case, you can dig the hole deeper and bury the head/make it level.
Dan
djlandkpl is offline   Reply With Quote
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 08-30-2013, 06:56 PM   #6
it will have to wait till I get back from vaca.
Old 08-30-2013, 07:00 PM   #7
One thing you might check. Many heads are installed flush with the ground then extend up with water pressure.
Yours wouldn't the first to get plugged with a little dirt and not slide down after it's done.
Just sayin'...you might check it.
RoyalAcresRod is offline   Reply With Quote
Old 08-30-2013, 08:14 PM   #8
that's an idea.
I thought it was pretty funny, with .30 of an acre and I've only seen 2 of these big things sticking up.
thanks
flexible head, or relocating rain bird sprinkler head? denemante Landscaping & Lawn Care 4 05-13-2013 08:23 AM
Sprinkler conversion from spray head to drip kevinf. Plumbing 3 04-25-2013 02:02 PM
Sprinkler Head doesn't rotate FlatBot Landscaping & Lawn Care 4 05-15-2012 05:43 PM
sprinkler head looking thing brianford Electrical 11 03-28-2011 07:13 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
