Spotlights To Illuminate Home - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-01-2008, 11:05 PM   #16
Chicagos Green Contractor
GreenContractor's Avatar
You are on the right track, the stuff at HD and lowes is pretty worthless, if you are looking for a consistent brite lite or accent lighting on a home. Look towards a local landscape supply, you can also search for a Unique or Kichler dealer near you. I used to own a landscape firm and would recommend both products.
GreenContractor is offline   Reply With Quote
Old 01-14-2008, 07:35 AM   #17
Personally, I'm not into the spotlight look. To me, it's a bit unnatural. Sunlight comes down, so shadows from spotlights are going the wrong way...picture that Halloween trick with the flashlight under your chin. The lintels and sills should cast shadows down, not up. To me, a more pleasing visual effect is to put down-pointing floods in the soffits. How about just a porch light?
How about just using some inside lights on timers? The windows will be lit making the house look occupied. You won't be wasting electricity by lighting the outside of the house when you're not there.
BTW, you can figure out the cost to light you place in $$ carbon dioxide release and pollution using the calculator at http://www.selene-ny.org/lightcost/
Tim
timp is offline   Reply With Quote
Old 02-05-2008, 03:13 PM   #18
lightit, how do the mr16's stack up against the par38. i want a good beam but dont want to have to wear my sunglasses at night. can you power a par38 on a low voltage system or do you need the direct line for that size bulb? thanks.
wildbill is offline   Reply With Quote
