-   -   Spigot Timer Knocks Hard When It Stops? (http://www.diychatroom.com/f16/spigot-timer-knocks-hard-when-stops-178666/)
dezandseth 05-03-2013 01:18 PM
I have a spigot in the back yard and I've attached a basic battery operated timer to it so I can automate the garden watering. It works fine but when the watering stops, it's like the valve slams shut. The pipe the spigot is attached to comes through the rafters in my garage and when the valve slams shut the whole pipe knocks. The pipe going through the rafters doesn't really appear to be attached very securely to anything, so maybe if I brace it to the rafters somehow it may stop/minimize the knock, but maybe not?
I'm familiar with water hammer. The plumbing in our house was doing that a few months ago but installing a new water pressure regulator solved that problem. Anyway, I thought I'd see if any of you have had the same kind of thing and if so, what did you do to stop it from happening. Thanks!
-seth
AllanJ 05-03-2013 08:07 PM
-seth
Get a washing machine hose water hammer arrestor. This has the same threads as a garden hose and spigot. Attach the arrestor to the spigot first, then add the timer unit.
dezandseth 05-03-2013 08:14 PM
Interesting! I'll check it out, thanks!!
-Seth
user1007 05-03-2013 09:34 PM
It certainly would not hurt to secure that pipe to structure with strapping or something too. :thumbsup:
dezandseth 05-04-2013 05:36 PM
I knew about water hammer arresters, but didn't realize they were available as a screw on option for washing machines. I picked one up per your recommendation and just installed it on my spigot about an hour ago. Worked like a charm! Thanks for your help, I appreciate it!
-Seth
