Solid 4 Inch Black Flex Drain Pipe Backflow Preventer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 05:26 AM   #1
Solid 4 inch black flex drain pipe backflow preventer
I live on the water and have a 4 inch drain pipe that goes through my bulkhead and drains into a wetland. When water floods into the wetland the water backs into my water collection tank. I need some type of backflow preventer or gate on the end of the 4inch drain. Does anything like that exist or can something be jury rigged?
fuge6 is offline   Reply With Quote
Old 11-12-2010, 06:50 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,600
Ayuh,.. A few well placed sandbags comes to mind...
Bondo is online now   Reply With Quote
Old 11-12-2010, 07:52 AM   #3
Rewards Points: 152
I'm not sure if they make the duckbill valves that small:
http://www.fullervalve.com/check-valves.asp
Otherwise, I've seen these backwater valves in use in sani. sewer applications:
http://www.backwater-valves.com/
burnt03 is online now   Reply With Quote
The Following User Says Thank You to burnt03 For This Useful Post:
fuge6 (11-13-2010)
Old 11-13-2010, 07:03 AM   #4
I appreciate your response. The Duckbill would work so I'll contact the company to see if I can find a valve that fits 4" drainpipe.
Old 11-14-2010, 10:58 PM   #5
Rewards Points: 1,088
Does water flood into the wetland only when it rains? If so, then this duckbill check valve may not do anything for you as your outflow will be backed up whether you have a valve or not, unless you a backup drain option.
handy man88 is offline   Reply With Quote
AC Coil drain pipe questions fritzycat1 HVAC 14 11-12-2010 03:51 PM
got spray-in foam in drain pipe - suggestions? pvrmeasap Plumbing 5 10-03-2010 11:09 AM
Replacing corroded metail drain pipe gschulte Plumbing 2 09-19-2010 08:21 PM
4 inch drain pipe econdave Building & Construction 7 06-04-2009 11:57 AM
Flex line from black pipe to appliance kennethjyoung Plumbing 9 02-24-2008 06:21 PM
