-   -   Solid 4 inch black flex drain pipe backflow preventer (http://www.diychatroom.com/f16/solid-4-inch-black-flex-drain-pipe-backflow-preventer-86506/)
fuge6 11-12-2010 05:26 AM
I live on the water and have a 4 inch drain pipe that goes through my bulkhead and drains into a wetland. When water floods into the wetland the water backs into my water collection tank. I need some type of backflow preventer or gate on the end of the 4inch drain. Does anything like that exist or can something be jury rigged?
Bondo 11-12-2010 06:50 AM
Ayuh,.. A few well placed sandbags comes to mind...
burnt03 11-12-2010 07:52 AM
I'm not sure if they make the duckbill valves that small:
http://www.fullervalve.com/check-valves.asp
Otherwise, I've seen these backwater valves in use in sani. sewer applications:
http://www.backwater-valves.com/
fuge6 11-13-2010 07:03 AM
I appreciate your response. The Duckbill would work so I'll contact the company to see if I can find a valve that fits 4" drainpipe.
handy man88 11-14-2010 10:58 PM
Does water flood into the wetland only when it rains? If so, then this duckbill check valve may not do anything for you as your outflow will be backed up whether you have a valve or not, unless you a backup drain option.
