Soaker Hoses - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 06:19 PM   #1
Soaker hoses
I need to put soaker hoses and was told it was best to bury them 6" out and 2" down. Do I need to worry about the squirting areas? I tried filling then but when I do it seems more pop up. Is there a certain hose I should buy or should I just go ahead and bury it? I live in San Antonio. Fyi
PhiL1227 is offline   Reply With Quote
Old 08-22-2011, 08:24 PM   #2
Rewards Points: 1,016
Soaker hoses
Welcome!
Not sure I fully understand what you are trying to accomplish.
I have drip/soaker hose running along a fence row to water the bushes there. Just laid it across the ground behind the bushes.
I also have a couple areas with drip system providing for specific plants - plastic lines, emitters, etc. This system is just laid on the ground - with pine straw as ground cover and coving the system as well.
If you are wanting to put in a lawn sprinkler system suggest a visit to a couple of the equipment vendor sites, they have a wealth of info there regarding design and installation.
____________
Vince
Old 08-22-2011, 08:29 PM   #3
Soaker hoses
Originally Posted by vsheetz
Welcome!
This is for foundation stabilization. Should have specified that. The soil is expanding away from the house cause we are in a drought.
Something to hold 2 hoses together? konsole Electrical 6 05-13-2011 10:38 PM
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 09:15 AM
No Heat: Pressure switch & Hoses forming traps Yooperman906 HVAC 22 01-04-2011 10:52 AM
calculating lbs per sq ft. to support soaker tub everguard General DIY Discussions 2 10-13-2009 02:14 PM
Help Extending Hoses, etc. for Washer/Dryer graphicsource Plumbing 2 03-27-2008 06:57 AM
