Snowblower Augers Wont Engage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 11:49 AM   #1
Snowblower Augers wont engage
I have an 8hp MTD two stage engine 5 speed 24in snowblower. I started the motor today and it runs and moves fine. When I went to engage the augers it sounded like it was chewing up ice (or gears) started smoking and stalled out. I checked the belts and they are fine. I removed the shear pins and lubricated the shaft and they are fine. I checked the drive plate and the friction wheel and they are fine. The chute and augers are clean and free. Not sure what to check next. Any suggestions.
ruszkowski is offline   Reply With Quote
Old 01-25-2011, 11:57 AM   #2
Rewards Points: 1,646
Anything stuck in 2nd stage impellers that are preventing them from turning? (Not the augers in front that first hit the snow).
bob22 is offline   Reply With Quote
Old 01-25-2011, 01:16 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... The Gearbox in the center of the augers....
Old 01-25-2011, 01:32 PM   #4
Nothing is stuck in the second stage impellers. Not sure how to check the gear box. It looks fine and smoke is not coming from that area, it is more right behind the second stage impellers where the belts engage.
Old 01-25-2011, 01:39 PM   #5
Bondo's Avatar
Ayuh,... That's the Belt burning up, because the shaft/ pulley won't turn....
Old 01-25-2011, 06:12 PM   #6
Had the same symptoms with my MTD as you mention.
For me last winter....in heavy wet snow my MTD gear box went out.
Thought the shear pins on the augers were supposed to break before that happened but...no no no.... So based on what happened to my the MTD can't handle heavy wet snow.... although this was one of the two back to back
1 1/2 footers we got here in Maryland last year...
Had to buy a roller pin tool to get the shaft separated..
Hope you find your's is a minor fix
handyd123 is offline   Reply With Quote
Old 02-21-2011, 09:42 PM   #7
I have gear box trouble with my 30" MTD and need to remove it!
Is it necessary to separate the engine section from the auger front end?
Or can the auger assembly be removed by removing the roller pins?
Old 02-21-2011, 10:48 PM   #8
Rewards Points: 1,536
With the shear pins in front removed, do the augers spin freely?
Have you opened up the middle and exposed the pulleys and clutches? After you find the augers spinning freely, can you easily rotate the pulley or wheel that activates the front section, namely the impeller and gear box and augers? (Use a stick poked at the pulley rim, not your hand)
Snowblower Electrical Question TimKLL Automotive Repairs 3 01-20-2011 07:10 PM
MTD Snowblower Problem tjwalker General DIY Discussions 9 11-30-2010 08:47 PM
Snowblower Repair FF_Thor General DIY Discussions 0 11-29-2010 03:51 PM
Toro 7/24 Snowblower - friction wheel Ottawa Landscaping & Lawn Care 1 02-02-2009 08:01 AM
Toro SnowBlower 521 metallic sound mteach General DIY Discussions 1 12-13-2007 12:27 PM
