Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-28-2011, 10:28 AM   #1
snow thrower wheel will not turn
I have a craftsman 2-stage model 994.524591 snow thrower. The left wheel will not engage when I apply power. It sort of "hits and misses", and stops at the lightest resistance. The right wheel engages as usual. I checked the parts repair exploded diagram, but wonder if there is a repair manual on-line that I could access. Or any other reference to help me in fixing this.
I can do some mechanical repairs but I am not familiar with snow throwers, so need help here.
Any and all responses appreciated
TIA.
amen2u is offline   Reply With Quote
Old 01-28-2011, 11:14 AM   #2
With the snow blower turned off and the wheels engaged, does the left wheel turn freely?
It could have an optional pin, visible at the wheel center or hub from the outside, that may have fallen out or broken. The pin is removed when you have to go around a lot of curves, where the wheels need to rotate at different rates. But this only works when you don't need that much traction.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 01-28-2011, 11:27 AM   #3
AllanJ: Thanks for the suggestion. I can turn the wheel manually under any conditions. You are right --- I suspect a shear pin or something like that has broken or has become disengaged. It's just that I have not worked on snow throwers before, so I really do not know what I am looking for. All I have is that exploded parts diagram.
Old 01-28-2011, 12:08 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,... That should be enough,...
Does it show a shear pin, or drive pin,..??
Google usually brings up any other manuals that Might be available...
Old 01-28-2011, 12:44 PM   #5
Usually it is, but as I said, I have no experience here. Here is the diagram. I think the toothed gears (21 & 23) must somehow mesh and drive the wheel.
I am going to taker it apart soon --- as soon as it warms up a bit. It is minus 20 Celsius here today and I have to work outside.
Old 01-28-2011, 01:10 PM   #6
It could be as involved as one of those gears, or a clutch, but I believe that Allan was referring to the item # 2 pins, so don't overlook a possibly simple fix. On most, or at least a lot of, snow blowers of this size, as Allan explained, one wheel can drive, or both wheels can drive, and it's usually a simple matter of removing or relocating one of those pins. On some of them, you will remove one pin for one wheel drive, or leave them both in place for two wheel drive. On others, such as my 20 year old Simplicity, you have two holes next to each other; with the pin in one hole it has one wheel drive, and with the pin in the other hole it has two wheel drive. Check to see if both of those pins are there before assuming that it's something more than that.
Old 01-28-2011, 01:17 PM   #7
All good advice and I will certainly check for a more obvious remedy than an all out repair.
I appreciate all the attention to my problem. It's great to be part of a group.
Thanks.
Old 01-28-2011, 01:34 PM   #8
Bondo's Avatar
Ayuh,... Lookin' at the picture,...
I'm guessin' maybe pin #2 fell out,...
Or,...
Key #27 is sheared off....
Or,...
The gear retained by #27 is stripped...
Old 01-28-2011, 02:02 PM   #9
OK. I think I found the answer. The diagram does not show the complete riggings. This model has what they call "Power Steering". This a bit of a laugh. On each handle is a turn trigger for the wheel on that side. It is connected via a cable to a lever that disengages the gear (Number 22 on the diagram), and that stops power to that wheel. It is supposed to make turning easier. I guess it does that --- a little. But with heavy winter gloves, the trigger mostly gets in the way.
This is not shown or mentioned anywhere in the manual. As usual.
What has happened is that it got stuck in the partial release position. This left the wheel disengaged. Everything up here is so cold that things like that are common.
Because it is so cold, all I did was temporarily detach the cable so it does not release the wheel power. It only took a couple of minutes to discover and fix, so my fingers only partially froze. I'll see if I can make any lasting improvements in the spring before I put it away for the summer.
And so it now works.
Thanks again for all the advice and encouragement. It is appreciated. I hope to repay in kind on this forum if I can.
Snow Thrower cable retainer Harleymansince7 Landscaping & Lawn Care 5 01-24-2011 11:21 PM
Need Help Replacing Spiral Blades on Snow Thrower cynergyou General Discussion 3 01-22-2011 09:53 AM
Dumb Question: How to turn Gas Fireplace Off? mark2741 HVAC 1 12-14-2010 09:36 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
