Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-27-2011, 09:10 PM   #1
snow blower will not hold a start
Hi Everyone. I have a yard machine snow blower and it starts fine. The problem is that it stalls out after about 10 seconds. If i keep pumping the primer it will keep going but i cant do the drive way while pressing the primer. I thought i may be the primer pump itself because it had a crack so i replaced it and still the same problem. Any ideas or advice would be great! Thanks.
Mike
bossmg2000 is offline   Reply With Quote
Old 01-27-2011, 10:39 PM   #2
A Little Of Everything
You need to clean your carb.
DrHicks is offline   Reply With Quote
Old 01-28-2011, 12:20 AM   #3
Moderator
Any closed gas line valve or pinched gas line? Give the engine maker a call; http://support.mtdproducts.com/app/a...etail/a_id/204
Gary
Clothes taking longer to dry?
Old 01-28-2011, 10:12 AM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,... I agree,... The carb has Crud in it...
Take it off, 'n disassemble it, Clean it, 'n rebuild it...
Rebuild Kits are available at small engine shops, or on-line....
Old 01-28-2011, 06:36 PM   #5
Mike
Did you open the choke after it started?
handy man88 is offline   Reply With Quote
Tags
engine, snow blower, stall, yard machine
Bryant Plus 90 - No Blower Ducaticorse HVAC 11 10-16-2012 09:39 PM
snow blower repair hctr1963 Gardening Forum 4 01-15-2011 07:06 PM
new snow blower blows snow back emmiespop Tools 1 01-12-2011 08:43 AM
Noma snow blower Gatineau General Discussion 1 01-16-2010 11:21 AM
Armstrong Air - Circulation Blower Not Start Chris-MN HVAC 3 06-23-2008 05:04 PM
