-   -   snow blower will not hold a start (http://www.diychatroom.com/f16/snow-blower-will-not-hold-start-93715/)
bossmg2000 01-27-2011 08:10 PM
Hi Everyone. I have a yard machine snow blower and it starts fine. The problem is that it stalls out after about 10 seconds. If i keep pumping the primer it will keep going but i cant do the drive way while pressing the primer. I thought i may be the primer pump itself because it had a crack so i replaced it and still the same problem. Any ideas or advice would be great! Thanks.
Mike
DrHicks 01-27-2011 09:39 PM
You need to clean your carb.
Gary in WA 01-27-2011 11:20 PM
Any closed gas line valve or pinched gas line? Give the engine maker a call; http://support.mtdproducts.com/app/a...etail/a_id/204
Gary
Bondo 01-28-2011 09:12 AM
Ayuh,... I agree,... The carb has Crud in it...
Take it off, 'n disassemble it, Clean it, 'n rebuild it...
Rebuild Kits are available at small engine shops, or on-line....
handy man88 01-28-2011 05:36 PM
Mike
Did you open the choke after it started?
