Snow Blower Mtd Runs But Doesn't Move - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 12:56 PM   #1
snow blower mtd runs but doesn't move
I have MTD model 31ae6lhg705 The engine runs but the wheels don't turn. I removed the bottom plate. The friction disc looks fine. The friction wheel looks good. The gears are locked. I removed the E-ring from the upper set of gears and slid them to the left. Now the remaining gears and the wheels turn. Sliding the gears to the right to engage them and again the gears are locked and the wheels won't turn. What would be the reason
peteE is offline   Reply With Quote
Old 03-01-2011, 10:30 AM   #2
Found the problem. The gear train has gears that are stationary and ones that spin freely on the shafts.. One of the freely spinning ones was frozen. This gear has needle bearings with out any way to lubricate it with out taking the gear train apart. My suggestion is to take apart the gear train at least once a year an lubricate those bearings or sooner or later you will have to replace the gears. Just short of a hundred dollars if you do it yourself.
snow blower issue, erratic engine reekeyg Introductions 4 01-31-2011 03:14 AM
snow blower will not hold a start bossmg2000 Landscaping & Lawn Care 4 01-28-2011 05:36 PM
snow blower repair hctr1963 Gardening Forum 4 01-15-2011 06:06 PM
How close to the ground should the blades of my snow blower be? J187 Landscaping & Lawn Care 2 01-28-2009 03:53 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 09:55 PM
