-   -   snow blower mtd runs but doesn't move (http://www.diychatroom.com/f16/snow-blower-mtd-runs-but-doesnt-move-96213/)
peteE 02-22-2011 01:56 PM
I have MTD model 31ae6lhg705 The engine runs but the wheels don't turn. I removed the bottom plate. The friction disc looks fine. The friction wheel looks good. The gears are locked. I removed the E-ring from the upper set of gears and slid them to the left. Now the remaining gears and the wheels turn. Sliding the gears to the right to engage them and again the gears are locked and the wheels won't turn. What would be the reason
peteE 03-01-2011 11:30 AM
Found the problem. The gear train has gears that are stationary and ones that spin freely on the shafts.. One of the freely spinning ones was frozen. This gear has needle bearings with out any way to lubricate it with out taking the gear train apart. My suggestion is to take apart the gear train at least once a year an lubricate those bearings or sooner or later you will have to replace the gears. Just short of a hundred dollars if you do it yourself.
