Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 12-05-2011, 11:40 AM   #1
Snapper Snow Blower Electric Starter
I replaced the electric starter on the snow blower however the hole for the lower screw on the starter is stripped and does not hold the starter in place. When you try to start the engine by pressing the starter is just spins and does not engage. If you press it against the engine it will engage. The part that the starter is attached to is plastic, any suggestions on how to hold it in place?
Irishhusker is offline   Reply With Quote
Old 12-05-2011, 01:17 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Slip a Nut in behind to hold the screw...
Old 10-05-2012, 10:05 AM   #3
You can try filling the stripped hole with JB weld, plastic and redrilling and tap.
wilbur427 is offline   Reply With Quote
Old 10-05-2012, 05:37 PM   #4
What Bondo said!
Canarywood1 is offline   Reply With Quote
Are you ready for SNOW & ICE ? Roofmaster417 Roofing 15 10-09-2011 10:25 AM
Snow blower paint robut Painting 5 02-20-2011 06:29 PM
Ariens snow blower damaged by garden hose Manuelg Appliances 0 01-23-2011 12:56 PM
snow blower repair hctr1963 Gardening Forum 4 01-15-2011 07:06 PM
Toro 521 electric starter repair hwm General Discussion 4 12-12-2007 10:28 PM
