Snapper Riding Mower Problem - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 08:10 PM   #1
Snapper riding mower problem
I have a Snapper 28" riding mower that has started to quit after the blades are engaged. If I'm fast enough to dis-engage the blades before the engine quits then it will keep running. If I do not engage the blades then it runs fine. Any ideas???
shobri01 is offline   Reply With Quote
Old 11-11-2010, 12:30 PM   #2
Try here. http://www.mylawnmowerforum.com/forum/ They have a dedicated Snapper topic if you scroll down.
Mike in Arkansas is offline   Reply With Quote
Old 11-11-2010, 07:21 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Will it stall if the blades are engaged with trans in neutral? if not I'd start by checking your safety switches
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 11-12-2010, 09:06 PM   #4
Rewards Points: 156
Either a safety switch is broken, the transmission is in reverse, or one of your blade spindles is seized up.
moondawg is offline   Reply With Quote
Old 11-15-2010, 01:18 AM   #5
Try this site - http://www.fixya.com/tags/snapper_mower. There are some information that can solve the problem.
Best,
Michelle a.k.a. Not Just Bras
bras-lingerie is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
My riding mower BABYGIRL44 Electrical 4 06-06-2010 10:24 AM
Audit your riding mower deck this spring tbeaulieu Landscaping & Lawn Care 1 05-12-2010 10:33 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
