Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 04-13-2006, 05:38 PM   #1
Home Owner
Small Patio
I recently purchased a condo. It has a small back patio with patio stones with a small garden around the one side.
Personally, I hate the look of patio stones but I don't want to get into pouring a concrete pad or anything.
Is there any alternatives ways to changing the look of the patio? Like an over lay of some sort?
Where can I find pictures of patio setups?
Thanks guys.
Leenders is offline   Reply With Quote
Old 04-13-2006, 06:08 PM   #2
Contractor
tgeb's Avatar
Small Patio
You could use brick pavers, fairly easy for an energetic DIY.
Check out Belgard.biz lots of photos and other info there.
Tom
Tom
tgeb is offline   Reply With Quote
Old 05-10-2006, 01:28 PM   #3
Small Patio
i found some good info on concrete overlays by going and downloading this book at http://www.decorativeconcreteguide.com
hope that might help in your project
clark
clark is offline   Reply With Quote
Old 06-23-2006, 02:01 PM   #4
Property Manager
Small Patio
As a quicker and possibly cheaper alternative, there are also prefab wood decking tiles available. You may be able to get away with laying down a thin base of limestone screening to level the area and then the decking tiles on top.
I’m a bigger fan of stone/concrete myself (no or at least less maintenance) since the wood decking will rot over time but this is a pretty good alternative.
MrNoMaintenance is offline   Reply With Quote
Old 06-23-2006, 02:30 PM   #5
Small Patio
Any Advice On Installing Tember Tech Tongue & Groove ?
Problems Or Ideas..
DRU mu is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Can a DIY build a small in-ground swimming pool? zel General Discussion 10 12-26-2007 06:41 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Patio & Carport Advice wdj03 Roofing 7 10-06-2006 05:59 PM
