Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 11-02-2011, 11:09 AM   #1
Small Engine Repair
I have an Old Homelite Generator model 180I62, WI-390 series 800448 (Wisconsin Engine). The carb has gas running out of the carb where the choke (butterfly is). And it won't start, could there be a blockage in the carb? I can't find any info online for this discontinued model.
chasgreen is offline   Reply With Quote
Old 11-02-2011, 01:11 PM   #2
Small Engine Repair
could be some dirt between the needle and seat. take the carb bowl off, being careful not to drop or lose the needle, float or pivot rod, and spray it clean with carb cleaner. also spray some cleaner into the seat. when you put it back together, you may want to use a small amt. of starting fluid sprayed into the carb intake. Also pull out the spark plug and check to see if it is fouled with fuel or oil.
packer_rich is offline   Reply With Quote
small engine carb trouble sd267 Automotive Repairs 8 05-17-2013 07:29 AM
11 hp OHV small engine has gas in oil Katz957 Landscaping & Lawn Care 2 10-18-2011 10:29 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Small Engine Tachometer Giles General Discussion 5 05-06-2011 07:50 AM
Small grumbling cement repair deck hand Building & Construction 6 03-28-2009 10:52 AM
