Small Engine Repair - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 08:28 PM   #1
small engine repair
I have a walk behind lawn mower with a Tecumseh engine. It starts but then dies. I have changed the air filter and the gas. I think the next step is cleaning the carburetor. That is if I knew what a carburetor looked like. Is it the small metal box on the side between the air filter and the spark plug? The gas line seems to go into it and it has holes on the side.
thoth713 is offline   Reply With Quote
Old 05-31-2011, 09:13 PM   #2
Rewards Points: 256
carburetor should have cables / linkages hooked onto it.
oldrivers is offline   Reply With Quote
Old 05-31-2011, 10:27 PM   #3
A Little Of Everything
Rewards Points: 1,356
What you're describing sounds like a cover of some sort. The carb is probably under it.
If you're this much of a novice (and I'm not saying that in a derogatory way at all) it might be a good idea to have somebody help you with this project. It's fairly simple to clean a carb, but fairly easy to screw it up.
Good luck!
DrHicks is offline   Reply With Quote
Old 07-10-2011, 07:25 AM   #4
carburetor identification
hello DIY Member,how are you today ?
if you are not sure what a carburetor is or what it looks like,just enter it in your search engine, ie google or bing etc and then click on images or videos.
plenty of information there .
hope this helps ,have fun and don't forget to wear your safety glasses please. all that fluid and small parts can be hazardous.
cheers
FlairCornwall is offline   Reply With Quote
Old 07-10-2011, 07:26 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
http://www.lawn-mower-shop.com/carb1.htm
http://www.psep.biz/store/tecumseh_carburetors.htm
You might want to just price out a replacement carb. Probably not very expensive, and easy enough to swap one out, even for a rookie
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
small engine carb trouble sd267 Automotive Repairs 8 05-17-2013 07:29 AM
Small Engine Tachometer Giles General DIY Discussions 5 05-06-2011 07:50 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Prep for tile in a small foyer Nick DIY Flooring 1 12-09-2010 07:40 PM
Small grumbling cement repair deck hand Building & Construction 6 03-28-2009 10:52 AM
