Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-18-2011, 06:26 PM   #1
Question
Small drainage problem
Hi all,
Not sure what the best way to get rid of this standing water against the curbing.
I thought about cutting lines into the curbing itself or building a small french ditch underneath the curbing. The latter seems like a lot of work for such a small issue.
The grass is suffocating and it's starting to rot and stink so I do need to do something soon about it.
I could let it evaporate but water collects there after the irrigation system runs and after every thunderstorm downpour.
edwardle is offline   Reply With Quote
Old 07-22-2011, 10:25 PM   #2
What is on the far side of the curbing? If the water went on the other side, for example if you drilled horizontal holes in the curbing to let the water around the grass drain, then would that cause a problem?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
under deck drainage problem Ranger1227 Landscaping & Lawn Care 1 04-10-2011 11:04 PM
Drainage Problem -- But Only During Snowmelt JoshW Landscaping & Lawn Care 2 06-12-2009 05:01 PM
Eavestrough Drainage Problem Midicat Landscaping & Lawn Care 1 09-10-2008 01:00 AM
Drainage problem - Rain Barrel? Leah Frances Landscaping & Lawn Care 4 01-30-2008 07:20 PM
Small engine problem rkhpapa General Discussion 1 12-09-2006 09:00 PM
