Slope Of Dirt Under Stone Patio Next To House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 09:32 AM   #1
Slope of dirt under stone patio next to house
I am planning to put in a paver patio next to the house. When excavating the dirt, should it be sloped or level? How about the paver patio, should it be sloped away from the house?
itneverends is offline   Reply With Quote
Old 06-14-2011, 09:44 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
The patio surface should be sloped away from the house. If they are the interlocking concrete pavers (4"x8" or so, depending on the shape/configuration), they should be set on a 1" uncompacted sand setting bed. The compacted base should also be sloped parallel to the paver top slope to maintain the 1" setting bed. - If you using the larger "stepping stones" (12x12 or larger), that is a totally different.
I don't see exactly how the second photo relates to the first, but there certainly has to be something done for your flimsy downspout set-up. - Perhaps pvc (not the cheap corrugated stuff) that could be incorporated under the patio surface.
No idea of the size of the patio or what the climate is, so anything else would be more of a guess than my small suggestion above.
Dick
concretemasonry is online now   Reply With Quote
Paver patio for raised foundation house? sandyman720 Landscaping & Lawn Care 1 05-06-2010 06:06 PM
slope needed around house? hellothere123 Landscaping & Lawn Care 1 03-31-2009 08:41 PM
Dirt at house is above lowest brick courses pmracing Landscaping & Lawn Care 5 03-26-2009 09:48 PM
build a stone house scarediecat Building & Construction 4 10-17-2008 05:51 AM
Building A Stone House In An Semi-Earthquake Enviroment Silverbackman Building & Construction 12 03-28-2006 03:43 AM
