Slate Wall Cap Flaking/cracking... How Do I Stop It? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 10:08 PM   #1
Slate wall cap flaking/cracking... how do I stop it?
I just bought this house and I noticed all these cracks in the slate (I think it's slate) cap that's on the front porch knee wall. Very large sections of the edge are cracking off like an iceburg. I guess that the water gets in there and freezes, hence the "birthing" of slabs as seen in the photos below. I put quikcrete stone sealer on it and it did NOTHING! The water doesn't even pool on the stone. I particularly brushed a lot into the cracks. What do I do short of silicone caulking all the cracks or painting it? Is there anything I can put on to preserve it and stop it from further deterioration?
Thank you very much.
Slate wall cap flaking/cracking... how do I stop it?-img_3895.jpg   Slate wall cap flaking/cracking... how do I stop it?-img_3896.jpg   Slate wall cap flaking/cracking... how do I stop it?-img_3897.jpg
h82diet is offline   Reply With Quote
Old 12-03-2011, 09:26 AM   #2
Have I posted this in the right place? Any suggestions where I might get a reply?
Thank you!
Old 12-03-2011, 09:37 AM   #3
Rewards Points: 13,250
There is no "fixing it" it's going to have to all come off. It was installed wrong and is just not going to hold up. Even If you replaced it because there is no overhang to prevent water from getting in behind it and poping it off again.
Looks like someone was trying to just cover up a cracking failing stoop to me.
Slate is one of the most brittle and stainable stones there is.
Looks like the best thing to do is remove and replace those failing steps.
Old 12-03-2011, 09:40 AM   #4
The slate is a cap on a knee wall. It never gets walked on.
Old 12-03-2011, 09:42 AM   #5
here's a photo of the wall from a distance
It is a cap on a short brick wall that surrounds the front porch and goes down the stairs under the railing.
Slate wall cap flaking/cracking... how do I stop it?-frontresize.jpg
Old 12-03-2011, 10:32 AM   #6
DIY staff
Rewards Points: 7,174
That looks more like limestone than slate on my monitor--
Some times you get a stone that spalls--The natural layers aren't tight and water get in--freezes and spalls.
You have two choices---live with it--or replace with a stone that will not spall---the stone yards know very well which is which.
Some Welsh slate is so stable that 200 to 300 years is the expected life--and they are reused--often seeing two or three different roofs in their life time.
Old 12-03-2011, 02:45 PM   #7
I have no idea what type of stone that is but the flaking bugs me. There has to be something I can seal it with... how about something like the stuff granite counter top people use to seal the granite? what about a marine polyurethane with a matte finish?
Old 12-03-2011, 04:40 PM   #8
DIY staff
Nothing will work---water is seeping into the tiny gaps between the layers of the stone--it then expands and pops the rock apart--
Sorry---but you have bad stone---
Old 12-03-2011, 07:05 PM   #9
Arg.... it's been there 111 years... I'm going to figure out something...probably not this winter because it's freezing out already but that spalling is going to STOP! I don't care if I have to paint it with liquid rubber (cringe.)
Old 12-03-2011, 07:12 PM   #10
That stone have not been on there that long, Someone stuck it on there.
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
How to stop a leak in basement wall? Ammons Home Building & Construction 6 03-04-2009 02:24 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
