Slate Walkway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 06:33 PM   #1
slate walkway
what is the best material to put under slate for a walkway? I have already put down RCA for strength. do I use sand or crushed stone or what ?
i
diymarty is offline   Reply With Quote
Old 12-15-2009, 07:36 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
What is your local (wherever you may be) definition of RCA and what are the local options?
concretemasonry is offline   Reply With Quote
Old 12-15-2009, 07:38 PM   #3
Civil Engineer
Rewards Points: 4,860
I have no idea what RCA stands for. My slate backyard walkway is built on coarse sand, and has stood up for about 20 years no problem.
Old 12-17-2009, 09:40 PM   #4
Too Short? Cut it Again!
I am curious too about RCA and what it means.
Your slate is thick enough to stand up as walkway, yes?
Old 12-18-2009, 09:43 AM   #5
ccarlisle's Avatar
Rca =
Depends on your local climate; where are you?
RCA is recycled concrete aggregate.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-19-2009, 08:07 AM   #6
LandDesigns
Laying Slate
It sounds like you would like to have a dry laid application. If the RCA is a type of aggregate, make sure that it is at least 4" thick and laid on soil that has not been disturbed.
You could use sand for the next layer and also for the joints. A dry laid application of slate would be similar to that for pavers. This might help.
Paver Installation
You do not need the edge restraint.
Susan Schlenger is offline   Reply With Quote
Old 12-19-2009, 08:33 AM   #7
ccarlisle's Avatar
It's a pleasure reading your posts and surfing your website, Susan.
Old 12-19-2009, 08:52 AM   #8
LandDesigns
Thank you so much!
By the way...love your Golden pic
Old 12-19-2009, 09:01 AM   #9
ccarlisle's Avatar
Thx...one of two we have. This one is what is known up here as an American Golden, as it has similarities with an American setter. The other one is a real Golden retriever. Brings me my tools whenever I need them.
Old 12-19-2009, 09:35 AM   #10
LandDesigns
We have a 3 year old and lost two too old age in the past few years. They are wonderful dogs. Brings you your tools? Cool!
Old 12-19-2009, 12:21 PM   #11
slate walkway
Daniel, I live on Long Island, NY RCA is recycled concrete aggragate - the slate I have will hold up for a walkway. I was watching Home Tele & thet reccommend crushed granite, but if coarse sand will work I'll try it. It's probably cheaper too. Marty
Old 12-19-2009, 12:23 PM   #12
slate walkway
Paver Installation
Susan, Thanks for your reply I will take your advice & mull it around with other suggestions I have gotten. Marty
Old 12-19-2009, 01:01 PM   #13
Civil Engineer
Granite is a rock composed of a variety of minerals, including quartz, feldspar, biotite, and others. Once crushed, granite behaves essentially identically to sand, which is sillicon dioxide (quartz). There is no reason to go to the trouble to obtain crushed granite when sand will work just as well, be more readily available, and be less expensive.
Old 12-19-2009, 02:22 PM   #14
LandDesigns
Marty,
Your welcome! Good luck with your project.
Old 12-21-2009, 05:02 AM   #15
Rewards Points: 410
Around here in the northern tip of Illinois ( clay) crushed roadbed gravel
( limestone here) is used 3/4" down to fines, vibrator compacted in ( in layers) for pavers.
The crushed rock is angular which locks tight together under the weight and vibrations ( use plenty of water to force out the air).
I was told 6" thick to guarantee the work by a well known contractor here.( I did 7-8")
Then 1/2 to 1" of course sand for final leveling.
Then polymeric sand ( http://www.supersandbond.com/) is used on top for between the joints and vibrated in with a rubber padded vibrator compactor.
This is how pavers are done correctly in this area, I don't know about slate.
High Gear is offline   Reply With Quote
Slate tile Termite Flooring 14 04-01-2010 09:05 PM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 04:59 PM
Tile over Tile over Slate - can slate be salvaged? jwilds1 Flooring 0 11-17-2009 03:27 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 05:52 PM
Slate Tile... Jshakour Flooring 13 04-24-2008 10:34 PM
