Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-23-2008, 11:32 AM   #1
Since my mower ran out of gas....runs rough
Since my lawn mower ran out of gas......it runs rough, & wants to stall. I assume the carb sucked up junk from the tank, removed carb & cleaned, screen was clean, cleaned gas tank,
when I tilt deck toward handle on rear wheels, it improves, but level or tilted other way, it gets worse. Changed oil, & new plug.
Briggs & Stratton
Model: 10A902
Type: 2189B3
Code: 01101851
checkin2 is offline   Reply With Quote
Old 07-23-2008, 04:30 PM   #2
47_47's Avatar
Did you change the fuel filter. You may have some junk trapped inside and it's restricting flow.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 07-23-2008, 10:31 PM   #3
There is no filter on this simple carb, just the screen on the end of the inlet tube from the tank, I just took it apart for the 5th time, cleaned every orifice, inspected it, & checks out good. I cannot buy a new carb, (plastic) as Briggs & Stratton does not carry them.
It runs good for the first 10 seconds from the primed gas, but goes back to chugging, I'm guessing maybe the vacuum drawing the gas is somehow weak, dont know that much about the part of the mower, but am going to look into it. Thank-you.
Old 07-24-2008, 01:46 PM   #4
would opening the fuel tank cap make the mower running longer... just for experimental see if it is really the fuel supply causing the choking....
I assume base on simple physics... when the tank cap open, fuel is easier to draw... you know.. air pressure..in take, out take...etc.....
well this definitely not a long term solution... if it even works... but it could be a diagnostic thing...
KUIPORNG is offline   Reply With Quote
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
Move basement toilet rough in 6-8" HVACman Plumbing 5 04-19-2008 08:45 PM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 01:24 PM
how to stop my mower from 'mulching' joeyboy Landscaping & Lawn Care 11 03-08-2008 11:04 AM
