Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-02-2009, 12:45 PM   #1
Sillcock handle replacement
Hello,
I am currently trying to replace the handle on my outside spigot that my hose will hook up to. The handle is broken so I must replace it...
I bought a simple $1 sill cock handle from the improvement store A and it seems simple enough, but I just can't seem to get the broken handle off..
There is a screw on the handle that I loosen but all that happens is the water turns on and the handle does not come off.
I turned the water off hoping that I'd be able to get it off, but still no luck ?!
Does anyone have advice or maybe the proper way to go about replacing a sill cock handle ??
I'd very much appreciate it. Thank you - Justin
jlbovo is offline   Reply With Quote
Old 08-02-2009, 06:07 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If the screw is removed the handle should come off, unless it is just held on by rust or corrosion. Spritz the middle down with a little solvent like WD-40 and pry it off or use a handle puller.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-02-2009, 08:09 PM   #3
Household Handyman
Mike's correct on this, but may I add: Sometimes you have to tap the bottom of the handle, or what's left of it, to get it off. Not beat it, tap it upwards while moving your hammer around so you tap all of the area. These handles are held on by a snug fit and the screw. Sometimes when they are put on, people will tend to tap too hard on them the set the screw down hard. You may also need to see which type handle you have/will need. Some of these have straight splines and some are square, they don't interchange. Good Luck, David
Old 08-03-2009, 04:06 PM   #4
Hey alright ! Thanks for the good advice in the replies. I will try to put that to good use tommorow. Thanks very much, I'll keep posted on how it goes ! - Justin
Old 08-03-2009, 10:46 PM   #5
Custom Cabinet Maker
If I understand this, sounds like you cant get the screw out AND cant get the handle off. If so open the valve all the way like u do with full on water, get a good grip on the underside if the handle and hold against yourself and that screw should come out, Mikes WD40 is a FER SURE. Tappin UP on the underside should break it free. Last trick b4 you rip it off in pcs LOL LOL after screw is out get a torch and heat the bottom of that handle and rap it again
skymaster is offline   Reply With Quote
Old 08-04-2009, 01:51 PM   #6
Ahh, I tried to follow that. But no such luck. I broke the rest of the handle off ! I think what I ended up doing was actully taking out the valve that has the seat on it with the handle and screw still attached.
It almost seems now that maybe if I just buy a new piece that has the valve and seat on it everything would be great. I have to check Home Depot or Lowes, I just don't know what to call it ?
I appreciate all help - Justin
Old 08-04-2009, 02:00 PM   #7
I have gas!
Clutchcargo's Avatar
It might be easier to replace the entire sill cock.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-04-2009, 02:16 PM   #8
concretemasonry's Avatar
Go to a real hardware store with the pieces in your hand and ask "What do I need?".
A good hardware store will be very reasonable (in cost) and probably tell you what to do and look out for. - Do not do it on a weekend since plumbers have high hourly rates then.
Dick
concretemasonry is online now   Reply With Quote
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 09:28 AM
Storm Door Handle Installation jogan General Discussion 3 06-09-2009 10:57 PM
deciphering faucet handle EdPDX Plumbing 1 11-05-2008 08:12 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 04:50 PM
Valley Shower/Tub Handle jhardin0515 Plumbing 1 05-05-2008 09:20 PM
