Should I Cut The Flowers Off This Bush? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 08:04 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Should I cut the flowers off this bush?
I have 2 of these, one blue, one pink.
I must admit .... I don't even know what it's called - they PO planted them - I just water them.
The heatwave didn't treat them so well .... as you can see it looks slightly roasted. Those flowers look beyond saving, if I chop them would that give the bush more energy to grow new ones or do I need to leave these on for other reasons?
CoconutPete is offline   Reply With Quote
Old 08-05-2011, 08:54 AM   #2
New to gardening myself, but I'm guessing those are snowball viburnum and the flowers can be cut without problem.
Many plants respond to "dead heading" by growing a second and third round of flowers, but I don't think the viburnums will. Not sure.
Stillwerkin is offline   Reply With Quote
Old 08-05-2011, 09:33 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Also not a gardener, but since one is blue and the other pink, I would guess they are hydrangeas.
The Following User Says Thank You to Blondesense For This Useful Post:
loneframer (08-06-2011)
Old 08-05-2011, 10:06 AM   #4
Rewards Points: 504
I think I have heard that term used before. One of my friends was dropping me off and his wife said "I like your hydrangeas"
I just said "thanks"
Old 08-05-2011, 10:09 AM   #5
you can over prune them so do some research. we trim ours back after the leaves fall but minimal at that, good luck
The older I get the better I was
Old 08-05-2011, 10:30 AM   #6
Rewards Points: 504
http://www.hydrangeashydrangeas.com/pruning.html
It seems it's OK to just chop those off!
I'm gonna see if I can get my wife to do it while I put up drywall tomorrow hehe.
Old 08-05-2011, 11:43 AM   #7
Learning by Doing
Leah Frances's Avatar
Love Hydrangeas. You can leave the flowers on and they dry very nicely on the shrub. I have a beautiful wreath made of dried hydrangea blooms.
Or, if you don't like them, cut them off.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-05-2011, 11:58 AM   #8
Rewards Points: 504
Leah:
I like them, they just look kinda "sad" as a result of the heatwave. I watered them as much as I could but as you can see it didn't really work.
I was hoping for new growth if I chopped them, which it appears there is slight hope for.
Old 08-05-2011, 12:10 PM   #9
Learning by Doing
Originally Posted by CoconutPete View Post
Leah:
If they are 'Droopy' don't cut them right now. It will force some new growth and that will stress-out an already stressed plant. If things cool off and yours start looking better... then cut away.
In CT you may get enough new growth to survive the first frost. Next year (if it isn't so freakin hot) cut them as soon as the ENTIRE shrub blooms - you may force a second round of blossoms. They will not be as large or brightly colored as the first, but if done early enough it will work.
BTW - don't cut back the 'dead looking' sticks that are left at the end of the year (unless you want a smaller shrub). They will come back to life in the spring. Hydrangeas can tolerate part shade and full sun (in fact, they bloom much better with more than 1/2 day of sun) but they have a lot of trouble in the heat. Mine are all droopy right now; even though I am putting tons of water on them.
Old 08-05-2011, 12:11 PM   #10
Learning by Doing
Also, just looked back at your pic and your shrub is looking FINE. Cut those puppies off and try for some new growth.
Old 08-05-2011, 04:40 PM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
Leah:
It is not the heat, this is just what they do. Mine looks the same way.
chrisn is online now   Reply With Quote
Old 08-05-2011, 08:51 PM   #12
Rewards Points: 1,514
After the petals dry up or fall off, cutting off the remains of flowers prevents the plant from devoting energy into producing seeds and often results in more flowers.
Sometimes this (deadheading) results in nothing different in which case all you lost was the time spent going through the plant and cutting off the remains.
Old 08-06-2011, 07:10 AM   #13
biggles's Avatar
sure cut the brown ons down to the next bud and they will push the late ones more to bloom...only one flower per stem/season no matter were you cut them but could be longer with your area might catch another bloom..they were looking for water might of lasted a little longer....the color is dictated by the acid/alkiline in your soil....if you see neighbors pink.. lavander...purple thats the dirt.you had a nice harvest there when it max'd out with color.trick i do with these to get a latter bloom is to cut them down to the frost line cover them with leaves and dump snow till the next spring ..and here they come...flower in late aug into sept out here
Old 08-08-2011, 09:57 AM   #14
Rewards Points: 504
"Deadheaed" them Friday. If nothing else it just looks cleaner. I actually got 2 or 3 small flowers on each already so I'd say time well spent.
Thanks.
what kind of bush is this and why does it look so bad tekksan Landscaping & Lawn Care 4 05-04-2010 08:01 PM
digging up a burning bush rcs451 Gardening Forum 7 04-26-2010 10:31 AM
Need Advice - Flowers or Flowering Plants on Sidewalk sarahharris Green Home Improvement 2 07-06-2009 10:39 AM
Burning Bush problems/questions sk8z Landscaping & Lawn Care 1 02-14-2008 12:28 PM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 07:00 PM
