#16 |
KemoSabe
Should I aerate and overseed?
It's my understanding that in the heat of the summer, weeds will outcompete the new grass seedlings in getting established. I know in my climate, if I aerated right now, I would destroy the crabgrass barrier I put down and my lawn would be overun with crabgrass and other weeds. I tend to get better results with cool season grasses, which perform better in the fall in regards to overseeding.
#17 | |
DIY Hack
Should I aerate and overseed?Quote:
I think the confusion (for me anyway) comes from you using the term overseeding. When I hear overseeding it implies that there is at least some healthy, established lawn there, you aren't really "overseeding" if your lawn is completely dead. If everything is toast, go for it.
Those who can, do... Those who can't criticize on the internet |
#18 | |
#19 | |
Don't know it all, yet!
"The first stage begins as sun scald if the turf has been growing fast and you get some hot, sunny days. The turf turns white and you may see blotches or patches in your lawn appear virtually overnight. Cool season grass is exactly that, it prefers cooler weather- not the high 80’s or 90’s- such weather places a huge demand for moisture on a shallow root system.... What else can be done to avoid and or minimize browning and or drought stress? Mow high, 3” minimum and don’t cut the lawn at high noon- this is not a western movie- mow in the am or late pm. Better yet, if the lawn does not need a cut, don’t mow it at all- skip a week or two. Your heavy tractor or mower will cause more damage by crushing delicate, weakened grass versus leaving it alone. Fertilizing, liming, and other proactive treatments can keep the lawn healthier going into hot/dry weather and help the grass recover faster. Avoid high soluble, quick release liquid fertilizer as this can burn and or cause an undesirable- unsustainable flush of growth. Aeration can help break up compacted soil and allow water to penetrate the surface and down into the root zone." My personal experience has been generally with fescue lawns and bermuda sportsfields, and occasionally zoysia and centipede. Also, it is my understanding that bluegrass, if watered at all, should be done lightly during this period as opposed to most irrigation schedules that follow once a week to a good soaking recommendations. All rhetoric nothwithstanding, I still maintain that aerating during "drought" will not harm a lawn in and of itself but then one has to wonder how or why a homeowner would be concerned with aerating but does not irrigate or other maintenance as was briefly mentioned in one post. Each goes hand-in-hand with the other as part of an overall maintenance program. But let's compare apples to apples, not sports fields and golf courses to bluegrass lawns. Two different cultural requirements. In leaving, I will share this story. My mother used to tell me that I would argue with a signpost. That could be true. I submit that one could either: A. Simply ignore false and inaccurate directions and simply follow the correct path. B. Correct the sign so that others who follow would not become lost. C. Stand there and try to convince the sign that it is wrong. Good day!
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right! Last edited by downunder; 08-24-2010 at 07:58 PM. |
#20 | ||
DIY Hack
#21 |
South Jersey
Wow, lots of posts in here. Didn't intend to cause a controversy.
1) I didn't have time to water the lawn because of my work schedule and can only water on Wednesdays, Fridays and Sundays due to water restrictions. If I had more time to take care of my lawn I'm sure it would look a lot better than it does now. My property is only 75ft x 100ft so aerating it would not take much time. I use an electric mower that weighs about 30 pounds and leave it around 3" tall. I've only mown twice this year at the beginning of the spring... it just hasn't had enough water to grow. I plan to have an irrigation system for next year so I'm hoping that can keep me from going through this again. 2) The grass isn't totally dead. I have white splotches scattered around the lawn. Right now it is probably 60% white and 40% green so there is still some life left in it. However, the spots where the grass is white if I pull on the grass blades they're not attached to anything. Like they just wilted away and died. Now, in one spot of my lawn I have beautiful green grass where the properties are designed to drain into. Since my neighbor has been watering like crazy the excess water is flowing into my yard and making some of my grass in that area very happy. |
#22 |
DIY Hack
overseed now, and water regularly for first 30-45 days. Everyday if you can, even if it's just you holding the hose for 10 minutes a day.
areate in spring
| Display Modes | |
