Shed Site Prep - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 03:52 PM   #1
Rewards Points: 258
shed site prep
okay i am going to be getting on of these:
http://www.lowes.com/pd_274588-25-LW...eds&facetInfo=
after next Friday. how should i prep the spot it is going, my thoughts are
place 9 concrete pavers on top of a weed barer, make them level
install a boarder around it and fill the area with stone.
redman88 is offline   Reply With Quote
Old 01-13-2013, 04:27 PM   #2
Rewards Points: 13,450
#1 I would never buy one of these.
Reasons being, way to flimsy, near impossable to keep the door working right.
I've only installed one but have torn down dozens.
Unless you build a full platform floor out of 2 X 8 pressure treated and at least pressure treated decking boards or Advantec subflooring you going to have issues.
Old 01-13-2013, 04:55 PM   #3
Rewards Points: 258
sorry didn't ask for an option on the shed, i have worked with them for the last 15 years, and know about the problems with them.
Old 01-13-2013, 05:22 PM   #4
funfool's Avatar
Rewards Points: 534
just a option, I have seen a few Tough sheds and they have a decent idea for foundation.
They use a heavy gauge metal stud for foundation, is basically 4 sides with studs running in between and whole thing is sitting on concrete blocks.
As others have said, not worth the $300 for the product you are buying, then build a foundation, and then pay extra for a floor. Could build something cheaper then what you are paying now.
But using metal studs for bearing walls as a foundation, is a cheap alternative and should work for you.
funfool is offline   Reply With Quote
Old 01-13-2013, 06:53 PM   #5
Rewards Points: 258
it does include the floor kit, and i am going to be setting that in on the concrete pavers.
Old 01-14-2013, 03:04 PM   #6
"You can do anything"-Mom
brockmiera's Avatar
What size are the pavers?
How much does the shed weight?
What kind of soil is it going on?
If you've been working with them for 15 years haven't you run across how to build a proper foundation for them?
brockmiera is offline   Reply With Quote
Old 01-14-2013, 04:47 PM   #7
Rewards Points: 258
right now i am debating about doing a full perimeter of 15 3/4 square pavers, and just doing a 9 6x17" pavers. the shed its self wont weight more then 300 lbs between the metal and the deck. the soil is a clay like material.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Cut a Shed Kit to Size? Kevalin Building & Construction 11 03-05-2012 08:48 PM
Wood Shed Construction- Town wants concrete pad? TJ_in_IL Building & Construction 20 07-26-2011 09:21 PM
How should I insulate my shed? kbizzle Building & Construction 19 06-21-2010 07:50 AM
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 10:31 AM
